I recently changed out the water pump... after posting on here, and someone suggested that it had a bad seal, that seems to have fixed the leak- Thanks!
I got everything back together,and I have another strange problem. I can get hot air out of the heater, a sign that the engine is geting warm (when the automatic climate control is working right (another problem for another post)), within several block of driving. But the temperature gauge doesn't move very far at all. If I leave the car running for like an hour or more, it barely gets to the bottom of norm.
It seems to have behaved like this eversince I had I took out the radiator out, and had it rebuilt, and then I installed it myself, about a year ago, but not this bad.
I am wondering if its a sign of a bad gauge, or do I need to 'bleed' the system, and get rid of any air in the top of the block? If thats the case, I bet I needed to do that when I put the radiator back in last time I had it apart, right?
thanks all!
thanks all!
Bryan Berndt
bryanb at bryanb.net
1988 Turbo Coupe, Automatic, all options except leather and sunroof
Cat back dual exhausts, No Muffler.
