Ya, check the U joints. Also, have a look at the big vibration damper thingy on the tranny end of the driveshaft to be sure it isnt getting loose. How long has it been since you had your wheels balanced? Does the vibration seem to be coming from the front or rear, or both? Also, check the 12 mm bolts that hold the rear of the DS to the companion flange on the diff to be sure they are tight.
