Turbobob_dup1
May 2003
Fredericton,N.B.,Canada
Can you beleive it?! Brand new Motorsport 9mm race wires and I'm getting jolts off them like crazy. I guess every company has bad mondays [Image: rolleyes.gif]
I put on a set of cheapy wires and the sputtering dissapeared completely. Nice to drive a smooth running car again.
As for the popping around 10lb boost...well it's back only worse.I've got alot of flex hose in the fender to connect the K&N and mabe it's collapsing. Tommorow I'm going to put it directly onto the VAM and see what happens.
Keep ya posted, Bob
More Boost!!
'87 turbocoupe finally done!! Pics soon.
87 Turbocoupe,T3/T4 turbo,much porting,AFPR,255lph pump,GN cooler,K&N in fender,gutted upper/knifed lower,big valve head,A237 cam ,60mm throttle body,Talon 1G BPV.
4 + 1 = 8!!
Let's start a pool on those cheapy wires. I take 30 days of regular driving [Image: biggrin.gif]
BJL
Williamstown, New Jersey
My 9mm Motorsport wires are sitting in my trunk, agian i broke the conencter off when i removed it to chnage spark plugs. Right now i hjave a set of borg warnmer wires form the junk yard when i purchased my used distbuter, gues they can hold up no missing, yet, but nwo i said it i bet i jinxed myself, but hey cars runng greta with otu my $47 9mm motorosport universal 4 cyl wires
Brian J Larkin
1988 Turbo Coupe 5spd, dark blue and shining like a peice of polished glass.
http://crazydriver358.5u.com
Brian Larkin
88TC 330,000 miles
Slightly Modified
PsycopathicBird
Aug 2001
Crofton, MD USA
so what wires should we run???? i had three set of bws since i started driving the car. 2 i melted [Image: eek.gif]
silver 88 TC with a new stock turbo, holley 155 fuel pump, gauge pod with a/f and boost, K&N cone, and a holley ignition control module, homemade air intake, bosch bypass valve, Single 3" exhaust, Gillis Valve, external Autometer fuel pressure gauge on hood, new falken 502s and stock replacement springs.
Bring on the track Baby!!
[email protected]
silver 88 TC with a new stock turbo, holley 155 fuel pump, gauge pod with a/f and boost, K&N cone, and a holley ignition control module, homemade air intake, bosch bypass valve, Single 3" exhaust, Gillis Valve, external Autometer fuel pressure gauge on hood, new falken 502s and stock replacement springs, ngk iridium plugs.
14.95 @ 91.8 so far....
[email protected]
I have been running the stock motorcraft replacement wires (not 9mm) on all my cars without problem. Every once in awhile it's possible to get a bad set, like with anything. The part number is in the part number forum.
GaryS#2
May 2001
B.C. Canada
I could hook you up with some decent wires from BC here.
"Aurora, SS spiral core."
I'm melting plugs with my MSD and no wire probs at all.
I just took out a set of Bosch Supers, the reg plugs, and am putting in some Bosch coppers.
Great thing is car never missed a beat, started first crank all the time.
My Ranger with DIS and new NGK's cranks and cranks till it fires.
It has same wires but needs the MSD attention.
Grocery Getter/Rice Cooker.
Turbobob_dup1
May 2003
I had Accel 300+ race wires on my turboCapri woth the super coil and they worked fine.
My parts guy says I should've goten the Morroso wires like he suggested and probably never would've had this prob.
More Boost!!
4 + 1 = 8!!
Nate K
Eastern Shore of Virginia
Stock motorcraft wires are the norm for a good wire set that works well.
Personally I prefer and use Taylors. They have a High Energy set specifically for the TC that runs about $22-28 available from Summit and others. I have never had a problem with them in over 6 years of using them.
90 Mustang LX 5.0L Notch
Cars I wish I still owned:
69 Coronet 440
70 Torino 351C
79 Bronco 351M/400 on 35's
79 Trans Am 403 (6.6L)
88 Cougar XR7 5.0L
Grant
Jul 2002
Thomasville, GA
Nate, what size are the Taylors? I assume you're talking about the Spiro-Pro's that Sac Mustang sells??
83 TC : full 3" exhaust, 17" 93 cobra wheels, many mods awaiting install once the engine's back in
Nate K
Grant, no these are not Spiro-Pro's from Sac Mustang.
These are:
Taylor Hi-Energy Wire set
Silicone Jacket/Boot
Double spring locking terminals
8mm
Resistor core
Blue color only
Temps up to 500 degrees
From Summit Racing Catalog http://www.summitracing.com/
Part # TAY-64667
Price $21.99
69 Coronet 440
70 Torino 351C
88 Cougar XR7 5.0L
