That circuit with the resistor (22,000 ohm, I think) is the IDM circuit. Yes, there should be the resistir there,but I dont think that is the cause of your problem.
COde 14 can be caused by a bad PIP, but more often by bad plug wires / cap / rotor / plugs radiating RFI/EMI, which interferes with the low voltage PIP signal. I know you just did a turn up with Motorcraft parts, but recheck to be sure all the lug wires are seated completely on the cap and plugs, coil, etc. Rare, but I have heard of plug wires being bad out of the box.
When it runs rough, does it seem lean? Could be an ECT telling the EEC coolant temp is too warm. Measure ECT resistance with motor cold. Resistance should be about 55,000 ohms, roughly, with 70 deg coolant. Id ohms are significantly lower, like 20,000 @ 70 deg, ECT is bad. An out of spec ECT often wont set a code unless it is really wacked out.
