Donnell
Sep 2008
Atlanta Ga
I am unable to get any lights at night on the dash for some reason need help lights not on also in the were you put the car in gear its auto?
Donnell Louis
xcrunnerbd
Oct 2006
Woodland, MI, USA
Check your fuses? anything else not working?
Project 13 sec. / 30mpg in '88 TC 5Speed : 15.91@89mph / 32+ mpg
On The Car: KN cone, 2-stage Gillis@ 15psi wired to fuel switch, Kirban AFPR @ 39psi, Walbro 255 HP FP, 130A 3G Alt., Full 3" Stinger Exhaust incl. cat. no muffler,
Shelf: .48 T3, ported E6, BPV
Martin
Aug 2001
Agassiz, BC, Canada
Fuse first. Quite often the dimmer switch, the rotating knob by the Fog Lamp switch screws up. Its a rheostat and as such if its adjusted lots, wears out, or if never adjusted, just plain gets rusty on the face wiring, and with age they fail. Sometimes winding it around real fast both ways allows the lights to come back on again. I'd check there for power in, healamp switch on, and see if there is anything coming out!
Boost High, Fly Low
tr_guy79
Jan 2004
SE PA (DELCO), USA
If it is the rheostat, rotating it all of the wasy around to "interior light on" will make the dash lights come on, as this deadshorts the ground that is run through it...
-Shane
