Bad IVR or something
Donnell Offline
I am unable to get any lights at night on the dash for some reason need help lights not on also in the were you put the car in gear its auto?
Donnell Louis
xcrunnerbd Offline
Check your fuses? anything else not working?
Shelf: .48 T3, ported E6, BPV
Martin Offline
Fuse first. Quite often the dimmer switch, the rotating knob by the Fog Lamp switch screws up. Its a rheostat and as such if its adjusted lots, wears out, or if never adjusted, just plain gets rusty on the face wiring, and with age they fail. Sometimes winding it around real fast both ways allows the lights to come back on again. I'd check there for power in, healamp switch on, and see if there is anything coming out!
Boost High, Fly Low
tr_guy79 Offline
If it is the rheostat, rotating it all of the wasy around to "interior light on" will make the dash lights come on, as this deadshorts the ground that is run through it...
-Shane
3rd Annual Philly Tri-State NATO Meet - http://natomessageboard.com/ultimatebb.p...p=1#000003
'87 - Range Roller 4* adv / 50 trim t04e / Ported E6 / Gutted Knifed intake / Stinger 3->2.5" / Adj. Cam Pulley / Warlboro 255
To Do: PIMP/MS2, FMIC, Bigger Inj
