Bad Accumulator
Kerry Offline
Hello. My accumulator has went bad after my turbocoupe having to sit for a couple of months. Does anyone know if it will hurt to drive the car until I can replace it? It still stops fine but I am concerned about burning up the motor from it clicking on and off every time that I need to stop. Thanks........KP
Kerry
1988 Turbo Coupe
5 speed
Jeff K Online
I wouldnt drive it much. I think you are more likely to burn up the relay than the motor.
BJL Offline
Moderator
my 88 has been clicking the pump on every stop for years. it hasnt hurt mine , yet. but i plan on converting to vacuum assist. so i wasnt concerned about it.
i would go too long with it, as it will reduc the life of the pump.
Brian Larkin
88TC 330,000 miles
Slightly Modified
Kerry Offline
Thanks for the quick replies guys. It isn't my main car so i can do without driving it very much at all. Am I correct that there is no way to refurbish the accumulator? Also what other vehicles do they come on besides the super coupes that might interchange? Thanks.........KP
Kerry
1988 Turbo Coupe
5 speed
Kerry Offline
I also found this one on ebay and it says it fits most common ABS systems including ford thunderbird. What do you all think?.......KP
http://www.ebay.com/itm/ACCUMULATOR-BALL...30&vxp=mtr
Kerry
1988 Turbo Coupe
5 speed
fishblock Offline
I would give it a try. Looks like the NOS unit I bought from the Ford dealer a couple of years ago, and its cheaper than what I spent.
I want to keep the abs system on my car as long as its working, if it fails I'll look at using a hydro boost system from a late model mustang and a 7.3l diesel power steering pump
vroooommmm
87 dark red coupe, 5 speed, gray leather - stock for now...
09 Tacoma double cab
89 GL1500 Goldwing
teal95 Offline
The same ABS system is used on the Mark VII. I've stolen the pressure switch off one before.
steve
'83 & '84 GT turbo EEC-Tuner
'85.5 & '86 SVO twEECer
2x '87 & '88 TC QuarterHorse
'93 LX 5.0 notch Moates chips
3x '95 & '96 GT
Jeff K Online
There are a few GM cars from that era that also used the Teves II ABS system. The late 80s Pontiac 6000 STE comes to mind.
vegas_ss Offline
I need one too... The eBay one doesn't look like it has the allen head fitting on the top. I think it would be quite a pain to install the accumulator ball trying to get a wrench on the fitting above the nipple Wink (that's what she said!)
5.0TurboCoupe1988 Offline
i have another one. i haven't heard from kerry to see if the one i sent him fixed his problem...
1988 TC 2.3/5-Speed, 148K
