I had a BOV hooked up for about a month, then took it out and went back to my stock setup. Now if I turn the car on, cruise in 1st gear up to like 3000/3500RPM, then let off throttle and let the car drift, I hear backfire. Its not really loud, kinda like just bubbling in the exhaust. Could this be because I ran a BOV and the car was running rich a lot so it's kinda like getting the old unburnt fuel out of the system. Is that possible? I have not checked fuel pressure since I owned the car... When I floor it the air fuel gauge starts at the 3rd notch, then when RPMs get higher, it goes to the 4th.
I'm sure any unburnt fuel is long gone. As rpms go over 3K the A/F richens up. This is programed into the computer
