axle!
Harvs Offline
I was doing the rear brakes on my TC when I noticed that on the driver side you can pull the rotor in and out like it was loose or broken. Is there a pin or something that came off inside or broke?
kennethl6 Offline
If your talking about axle end play, .030" play is normal. More than that may mean worn Traction-Lok clutches.
??????? The rotor isnt "attached" to anything. It just slips on the wheel studs, and is held firmly in place by the wheel / lug nuts.
