Have a new aux shaft and distributor I am planning on swapping into my 87 turbocoupe as the distributor gear seems to be wearing down some an looks quite a bit thinner than the new parts.
Questions are...
The aux shaft doesn't have the drive pin and I can't seem to get the pin out of the old shaft... I didn't try real hard as I don't want to mess it up. It may be better to just find a new drive pin but I don't seem to be able to find one. I guess I could take the parts to a machine shop?
I have a new seal, however I was not sure about the thin gasket around the aux shaft seal housing... should I just get a new front cover seal an cut off the part around the aux cover to use? It doesn't seem like there is much to seal up?
Thanks
Questions are...
Thanks
1996 Impala SS
1996 Impala SS
