turbocoupe88
Mar 2002
Philly,Pa
I just picked up a 5" Autometer Tach for cheap and wanted to put it in my 85 Turbocoupe. I have everything wired up except for the green wire running off the tach, my quetion is what wire should I hook this up to and where is it? I bought this without directions and looked them up on autometer.com but I was just wondering what specific wire i should splice into on my 85TC so that I dont screw anything up. Thanks
Green wire on aftermarket tachs is usually tch signal input, which goes to the negative (switched) side of the coil. Other wires are probably red - 12V key on, black - ground, white or yellow - lighting.
turbocoupe88
Mar 2002
Philly,Pa
So I should be looking for a green wire with a yellow stripe at the coil, right? When I hooked one to my 88 I spliced into the green/yellow wire coming off the distributor where the spout is, that you unplug to set the timing.
Best to NOT hook up tach input to the SPOUT circuit. SPOUT circuit just sends computed timing signal to TFI to tell it to fire the coil. This circuit should be left alone. Just tie the tach into the COIL negative side, which is NOT the same as the SPOUT circuit. I dont remember off hand what the coil connector color codes are.... Pull connector off coil, turn key on. One connector terminal will read 12 V, other should read low volts (close to zero). Hook tach to the one that is not 12V. Alternatively, run one side of a test light to ground, and probe both coil terminals with car idling. One will have light on constantly, one will have light flicker. Hook tach to coil terminal with flickering test light.
turbocoupe88
Mar 2002
Philly,Pa
Ok thanks I got it hooked up now. Just got to find a place to mount this damn thing, its too big for the A-pillar and I'm not drilling any holes into my almost crack-free dash. I have it on the steering column now, covering up the stock tach but I think i need to find a new location for the shift light. That thing is bright and might be too much of a distraction at night where it is now. Ill have to wait and see. Thanks for the help.
karnage
Mar 2003
Olympia, WA.
I mounted mine on the left side of the steering column.Covers the stock tach.
84 TC with 88 hood LA-3 full 3" exhaust Rods header ported/polished big valve head schneider roller cam RW adj cam gear Kirban gillis at 20 # boost MSD ignition 255 lph Walbro full gauges
17 inch centerlines 944 front mount IC 80mm MAF
65mm tb-rotated intake on the way to 400HP
