Autolamp
Bandit524 Offline
Lights are always on with Autolamp wheel on day or night and no delay regardless of wheel setting. I think its the sensor--how do you remove the center top trim panel to replace the sensor?
Ed
Joe F Offline
It's press fit in and held in place with little plastic latch thingies. It's a pretty tight press fit so be careful, try using a wide piece of metal to distribute the prying force over a large section of the dash to avoid cracking it. BTDT.
Even if the sensor is bad the delay should work, especially when turning the headlamps off. If it's not, I'd suspect the switch/module.
HTH
Bandit524 Offline
Is the (switch/module) one item or two and where is it/they located?
Ed
Joe F Offline
Am at work so without my EVTM, so "as I recall" the switch and module are one piece located at...
the switch! (Sorry couldn't resist) Big Grin
If this turns out to be wrong please post and I'll look in the EVTM this weekend for you.
Good luck.
Michael Offline
This sounds dumb, but I have to ask. Is the manual light switch turned on, or is it off? That preceeds the auto feature...
1983 Turbo RS Rock Stock
1984 Turbo RS Capri 20+PSI
1988 Turbo T-Bird Tricked Out
1987 Turbo T-bird Dont Know Yet
1974 260Z (Early)-2.3T Conversion
Bandit524 Offline
Manual Switch Off. Although it might be plausible to make a bonehead mistake like that I can proudly say I didn't. Thanks for asking though!
Ed
Joe F Offline
The manual switch in fact overrides the autolamp feature. If you forget and leave them on, you wind up with a dead battery!
Bandit524 Offline
That's what the headlight on chime is for!
