ARP stud questions
trashline Offline
I spoke to an ARP techie today about there 2.3L non undercut studs for the 4 banger. She told me since Im running above stock boost it is a good idea to torque to 85 ft/lbs instead of the recommended 80. This is with there moly lube of course. If your using straight oil then you could increase as well I would assume.
My question is while following proper torque sequence order what are good increments to follow? would it be 30/60/85? I dont know b/c this is how I did it before. I couldnt find anything about it online or in the directions. I was just curious if anybody else followed something similier.
Brian
www.BCPCustom.com
06 Cobalt SS
66 mustang 289 C4 handfully modded
Stingers IC install and tbird photos
http://community.webshots.com/user/trashline
The Ford manual uses two steps with the first increment at 50 to 60 lb. ft.
I like to use a 3 step and I don't have any great rational for it other than a lower difference between torqued and untorqued bolts and from one increment to the next. I did suggest three steps in the Tech Article on changing head gaskets.
I know ARP recommends higher torques if you use regular oil rather than their special lube, but I don't know what the actual spec is.
trashline Offline
If I remember right ARP states 120ft/lbs for torque with motor oil.
Brian
www.BCPCustom.com
06 Cobalt SS
Joe F Offline
Just use their moly lube and torque to their recomendations - it was 80ft-lbs on my aluminum head with undercut studs. FWIW, I went 20-40-60-80 for the same reason Pete did. So far so good.
trashline Offline
Do you wait in between each torque?
Brian
www.BCPCustom.com
06 Cobalt SS
Joe F Offline
Just tighten all in the proper order to the fisrt setpoint, then readjust you wrench for the second, and repeat. No waiting necessary.
