John B
Dec 2015
New Jersey
So I got my hands on an Energy Suspension Poly trans mount. Part number is 4.1104G. On their website, it states that this mount won’t work with the 2.3 but it’s compatible with the 5.0.. there’s a review on summit racing where an individual said that this mount does indeed work with 88 TC as long as you remove the mount and the bracket. Does anyone have any personal experience with this mount? Is the trans mount bracket the piece that sits between the mount as trans with the two larger bolts?
John B
Dec 2015
New Jersey
Looks like some people have used this mount in the past. Still on the fence as to whether or not I’ll use it.
anasazi4st
Feb 2015
Phoenix, AZ
Engine and transmission mounts are not something I’d try to save money on.
BJL
Williamstown, New Jersey
i use this style on my TC, but its an 88 with all 83 5spd swap components.
Brian J Larkin
88TC 320k miles
89 Cougar XR7 3.8SC Auto
95 Ranger Splash 3.0 auto
John B
Dec 2015
New Jersey
anasazi4st Wrote:Engine and transmission mounts are not something I’d try to save money on.
?? Who said anything about saving money? I acquired this mount and was curious to see if anyone has actually used it on their TC.. As a FYI, I have a true "single bolt" poly trans mount coming in the mail.
John B
Dec 2015
New Jersey
BJL Wrote:i use this style on my TC, but its an 88 with all 83 5spd swap components.
Interesting; there's a member on here that is reproducing poly trans and motor mounts for our cars. Just purchased all three yesterday
