Anyone use MaxPSI Racing's oil return line?
cbpldc Offline
I think mine was just a touch too long as it kinks a little bit when the turbo is installed.
Although there is so little hose there, I hesistate to call it kinked. Do you think this could be causing my problem?
Chris
Blue 87 T/C, basically stock and slow.
Black 85 T/C. The race car.
1owner88TC Offline
Why don't you contact MaxPSI about the problem? Several folks at turboford.org use their oil lines, try them. I wanted to get the supply/return kit but one of the lines doesn't work on an IHI for lack of an available fitting. They are supposed to work fine on a T3.
fun, fun, fun - Justin
3" DP & Cat, Magnaflos, K&N, Magnecor Race wires, Steeda Tri-Ax, SPEC Stage 2 clutch, 3-core radiator.
