Anyone here ever put a fuel cell in their TBIrd?
Chuck W Offline
I the pusuit to get things rolling for the TBird I realized I need a gas tank..or fuel cell and or various asundries to provide fuel to the motor that will be going into the TBird. Since this car may eventually see some open track duty I was considering going the fuel cell route instead of a std factory tank. I may just stick a tank in there for now w/ a 255 l/hr pump and be done with it, but I was exploring options.
shiftless Offline
no, but i WANT one. the coughing and sputtering when i get below a half tank of gas gets old quick.
Dan E Offline
Brian Bitters has one in his...
Dan Eaves
Dan Eaves
Glenn 88TC Offline
Yeah and he is going to put the factory tank back in. He hates it.
Glenn 88TC
current mods (13.809 at 98.48mph): ported & polished big valve head(1.89/1.59), ranger roller, gutted upper and ported lower intakes, t3/t4 turbo, MSD 6al, MSD Launch Control, K&N filter, Walboro 255 pump, Kirban adj. fuel reg., ATR header, full 3" exhaust with Dynomax Ultraflow muffler, Star stage III ceramic clutch, Tiny Avenger bleed valve, Weld Draglites with M/T ET Street 26x11.5/15
Winter 2001-2002 upgrades - powerstroke intercooler(mounted full size or it won't be going in), 65mm throttle body, 42lb. injectors, custom grind roller cam, big turbo, rear suspension upgrades
NO TC and NO headaches.
shiftless Offline
is there a junkyard tank out there that'll bolt in to an 87-88 TC with little modification, has nearly the same capacity, and has baffles?
