http://beta.summitracing.com/parts/CMB-15-0075/
I know its for a mustang but from what Ive seen the chassis are very similar, would there be a problem using this and if so does anybody know where I would be able to find some stiffer springs for a turbo coupe?
Silver 88 TC: A few bolt-ons our suspension/chassis development car. My DD
Silver 88 TC: Grassroots Motorsports $2009 challenge car
Black 88 TC: Brian's DD
bang4thebuck
Jul 2004
pennsville NJ
If you cut between 1/2 coil to 1 full coil, not only does it lower your car but it makes it a little bit stiffer too. I wouldnt ever reccomend cutting more than 1 full coil! I have 1/2 coil cut off the front and the car rides super nice and it lowered the front almost an about 3/4 inch.
hair_dryer_powered_4
May 2009
sherwood park,ab
hey! would that lowering kit work in my car. its an 87 but a 4 cylinder.
The Crow
Kind of. In my research Ive found a few things:
Mustang front shocks work fine however SN95 fronts being slightly longer are a better choice even though they sacrifice a slight amount of droop travel
Mustang rear shocks require a modification to the lower mount as they are too short. Chuck W. on foxtbirdcougarforums makes these.
Mustang front springs are great. I personally would use V8 mustang springs as the Tbird is a heavier car
Mustang rear springs are much too short without the use of the CHE adjustable perch lower control arms.
In the near future I will be releasing a few Thunderbird/Cougar specific suspension kits I would wait on one of them.
May 2009
sherwood park,ab
thanks for the info
The Crow
