Pull the 7 connector off the top of the valve block. Measure resistance from pins 1 to 7 (end pin to end pin), which are the terminals for the RF inlet valve. Resistance should be in the 3 to 5 ohm range. If it is 0 ohms or infinite ohms, the solenoid is bad. If that is the case, the entire MC sssy needs to be replaced, as the valve block cant be serviced.
