revamp
May 2002
Norristown, PA
Hey.. My anti lock brake light has been on since I've gotten then car. The owner before that said they had no clue why it was on. Think maybe it is the sensors? or the ABS computer? I am not sure. I've got a backup ABS computer but haven't tried it yet. Let me know if any of you has had this problem.
Thanks,
Andrew
88 TC W/ 87K:
K&N in custom sanded airbox||Gillis Valve||Stereo Sytem: Pioneer 8400, Infinity Ref. Series & Polk Audio Speakers Powered by 4 Channel Pioneer Amps||Performance Radiator & Cooling System||Custom Interior Converion||Gutted Cat & Dynamax Ultra Flow Muffler||Indiglo Gauges ||and more to come!
Get the codes out of the ABS computer and let us know. To get the codes:
To extract the ABS codes, find the ABS test connector in the trunk. It looks just like the EEC test connector under the hood. Hold it so the row of 4 terminals is on the top, and the 2 terminal row is on the bottom.
Jumper the bottom left terminal (black wire) to the second from the left in the top row (orange / white wire). Turn on the ignition. The ABS light will flash codes. Let us know the results. (originally posted by Jeff K)
segfaultxr7
Aug 2001
Cape Coral, FL
By the way, I had an intermittent ABS light on my 88 TC. When I scanned for codes like Pete said, I got a code 21 (main valve or wiring problem). It turned out that there is a 2-wire plug on the part of the ABS module that faces the front of the car. For some reason the factory wiring was so ridiculously short that the plug was starting to pull out of the socket. I soldered some extra wire in to give it some slack and never saw that light again.
I saw an 88 TC in the junkyard and that wire was way too short as well, so maybe it's a common problem with these cars. Good luck, I hope you are able to fix your problem as cheaply as I was. [Image: wink.gif]
[This message has been edited by segfaultxr7 (edited 06-23-2002).]
88 TC 5-speed
Check the relays. Also a common problem. I think $25-$30 each.
[This message has been edited by Birdman78758 (edited 06-24-2002).]
revamp
May 2002
Norristown, PA
Hey,
Where is the test connector located in the trunk? I have not had time to look for it yet. Anyone know of the exact location for it?
Thanks,
Andrew
88 TC W/ 87K:
Matt S
Mountlake Terrace, WA
Quote:Originally posted by revamp:
Hey,
Thanks,
Andrew
Remove the spare tire cover and it's back there around the strut tower (drivers side)...you'll find it; may have to dig for it. Looks just like the EEC one under the hood. I took out the spare also to get to it easier.
Sold it  *
