Anti Brake Light on
Donnell Offline
My T/C Brakes are hard as a Brick can't drive because its dangers to drive can't stop.......Any help out here on the forums !
Donnell Louis
This a like the 4th time you have posted this problem. I ask again, have you run the complete diagnostics posted in the tech articles? If not, I (or probably anyone else) wont be able to help you much, if at all.
1988turbotbird Offline
Did you check for ABS codes?
ABS codes wont show anything for the actual electro-hydraulic power brake system. The power brake and ABS systems are 100% independent of each other.
tr_guy79 Offline
With the exception of the accumulator. If the pump doesnt run, you will end up with hard brakes. If you have a bad ignition switch, it can cause the ABS light, AND the hard brakes.
-Shane
3rd Annual Philly Tri-State NATO Meet - http://natomessageboard.com/ultimatebb.p...p=1#000003
'87 - Range Roller 4* adv / 50 trim t04e / Ported E6 / Gutted Knifed intake / Stinger 3->2.5" / Adj. Cam Pulley / Warlboro 255
To Do: PIMP/MS2, FMIC, Bigger Inj
