Once again; I need some help determine parts on my 88 TC. The first thing is the bracket of “stuff†behind the passenger strut tower. I thought I read that some of it was for the EGR but I have no idea. The second item is a random vacuum hose with what appears to be a gromet on it. Hopefully you can see the part number in the picture. I tried looking it up but didn’t find anything. This vacuum like has a tee in it. One end goes to vacuum manifold and the other line appears to run into the cabinet (boost gauge??). As always help is always appreciated
Behind passenger strut tower
Random vacuum line
Random vacuum line
