another option besides SDS or stand alone
86XR7auto Offline
Moderator
http://www.fullthrottletech.com/showthread.php?t=1155
A good friend of mine pointed this out. This technology is designed by Bob Bailey. This guy is super smart. He also designed translator, translator+, scanmaster series of scantools for GM cars, DSM, Supras
I guess you are supposed to be able to setup bigger injectors, use a GM maf, or speed density. Hooks to a laptop for tuning or you can use the small controller. Soon the unit will have wideband WOT fuel corrections. If you have a LM1 this would be great. Set in at 11.5 all the way to 6500rpm. Life would be good. $399 to start with. Get some cheap mopar injecters, T3/T4, lean out the bottom end for spool, fat on the big end to keep the engine together.
I personally going to keep an eye on this...
Getting rid of the VAM would be OK to me.
Just thought would guys would like to know.
Travis
86XR7, 85.5 junkyard motor w/165, 88TC 5speed, Spec 3 Clutch/Plate, GN IC w/scoop, 180 stat, 3" bob elbow, SMC Alky /10jet, Stock turbo, Gillis, Adj FP, big Fuel Pump, stock gearing, only MC tuneup stuff, autolites 103 gapped .30, 24psi, 19degrees base timing, stock everything else, no porting... [email protected]
