Ancillary Gauges
DaleLeo Offline
1- Thanks to all who helped with A pillar gauge mount advice.  I'm all set thanks to your help.
Im going to go with boost, water temp and oil pressure.
2- New question --- what gauge brand / series did you select?
Thank you
Daler
88Slowbird Offline
I typically run Autometer gauges, I prefer the electric ones so you don't have to run that copper or plastic line
Equus gauges seem to work well and they're cheap
Mach 1 Red 1988 TC: Steeda Tri-Ax shifter, manual boost controller, Stinger FMIC, Boport valve springs, Chip's Ranger R cam, Forge BOV
DaleLeo Offline
(01-23-2023, 07:40 PM)88Slowbird Wrote: I typically run Autometer gauges, I prefer the electric ones so you don't have to run that copper or plastic line
Thank you!
Kuch Offline
I also recommend the Autometer gauges, classic look for our cars. I originally had gauges in the A pillar but then switched to the cleaner looking center panel area. here's how I did mine and the gauges I used, https://turbotbird.com/showthread.php?ti...ght=gauges
https://turbotbird.com/showthread.php?ti...light=dash
spittinfire Offline
I'm going with Autometer GS series because I think it looks the closest to the stock gauges and I wanted to run an analog air/fuel gauge. The GS series was the only one close to the stock gauges with that specific gauge. The Z series looks similar to the stock gauges as well.
DaleLeo Offline
(02-20-2023, 01:00 PM)spittinfire Wrote: I'm going with Autometer GS series because I think it looks the closest to the stock gauges and I wanted to run an analog air/fuel gauge.  The GS series was the only one close to the stock gauges with that specific gauge.  The Z series looks similar to the stock gauges as well.
Hi
I looked at GS and liked them but felt that the chrome was too much for my planned A pillar mounting.  I went with the Z series.
Did you mount yours on the A pillar or some other way?
spittinfire Offline
Hi
I'm going to mount them on the A pillar and I plan to paint the bezel black because I don't want the silver there either.
