michaelantunano
Jan 2010
Valrico, FL
I have two 12" subs and an amp. I have the subs hooked up to the amp and everything set up right. the only thing left is the battery cable. What is the easiest place to put the caable through the firewall?
1988 White Thunderbird Turbo. Red Interior. Mods: Walbro 255. More to come...
UglyBird85
Jan 2009
Norfolk, Va
I just ran it through where Pete ran his line for his boost gauge. The lil rubber boot around the steering assembly that goes into the firewall. Just stuck a steak knife into it and left it in while I ran the cable through.
---Justin
87 Burgundy TC 5spd. K&N Cone filter-Walboro 255HP-.60/.63 Garret T3-Gillis @ 18psi.
SHELF: NPR FMIC-Ford Racing 42# injectors-Tripminder-
zbird
Jul 2008
Joshua, Texas
Just be sure to RTV that hole or you may get water forced into the passenger compartment!!
michaelantunano
Jan 2010
Valrico, FL
michaelantunano
Jan 2010
Valrico, FL
Is there a picture of where Pete ran his boost gauge? That would help a little.
