ammeter
adamh Offline
I was wondering which wires are for the ammeter on a 85 tc. Mine doesnt work anymore thanks to a small fire, from previous owner intsalling a 3g alt. Do i need the ammeter hooked up at all? Was thinking about removing it and replacing it with a volt meter down the road.
peace out
IMHO there are probably more non-working TC amp gauges than working ones. I though I saw one move once, but I'm not sure anymore
My 1988 Ford EVTM manual shows a red w/ orange wire and a yellow w/ light green. Yours may be different
adamh Offline
Thanks. I'll.look into it when it stops raining.
peace out
Joe F Offline
Yeah, great idea on the voltmeter; it'll tell you more.
I think I may have seen my ammeter twitch a little, once or twice, before I replaced it with a voltmeter!
TurboE Offline
From memory the 3g alt install on this site tells you about splicing in for the ammeter?? but it's been a long while I could be misinforming? Might want to start with the 3g intall instructions on this forum also to get an idea.
-88 TC Black
-97 Pathfinder
84TBirdTurbo42 Offline
i have seen the one of my 83 stang move before. but thats because the idle is so low with the cam. i've got a hunch that there more of a on/off switch like the oil pressure gauges in later fords.
Chris Perry
The amp meter is a "shunt type" meter. There is a calibtated resistance wire of a fraction of an ohm in the alt output lead. When current flows thru this there is a volt drop across the wire (Ohms Law). The "amp" meter is really a volt meter that reads this volt drop. To add more confusion, all volt meters are really amp meters, so another way to think of the shunt type system is the meter and shunt wire act as a current divider, with only a very small fraction of the total alt current flowing thru the amp meter.
The problem with the meter is the magnets inside it become demagnetized and it doesnt indicate anything.
Rod K Offline
When I did my 3g upgrade I got a voltmeter from an '89 Tbird. I took the movement and put it in the ammeter location in my gauge cluster. I had to take the TurboCoupe needle and JB weld the hub from the 89 gauge to the TC Needle. It looks stock. With the switch on and the car not running the needle points to the center of the gauge. Turn on the lights and it shows a discharge. Crank the car and the needle goes about 80% of the way to the top of the positive side of the meter.
It has been like this for about six years and 50,000 miles. It still works perfectly.
I did have to wire the gauge as a voltmeter.
Rod Kiser, '88TC, 5 speed, 5 lug, Cobra 13" front brakes, Mark VII 11 1/4" rear disc brakes, PiMP'n, Bullit wheels, ATR 3" exhaust, Aluminum driveshaft, EDIS, 60 LB injectors, gutted upper & ported lower. NATO Member
