Gulfdiver
Jan 2006
Spanish Fort, AL.
Do I need to use a gasket with an aluminum TStat housing with the rubber o-ring seal?
!!!!! MINE ALL MINE !!!!!
1988 TBird Turbo Coupe Mach 1 Special Edition
K&N airfilter; Spec Stage 3.. More mods to come!
turbobird63
Jan 2003
Telford, PA
no
Christopher Taylor
85 TC, 2.3l, LA3, T3/T4 Turbo 25psi, Stinger FMIC, Forge BOV, Full 3" Exhaust, Esslinger crank pulley- Timing Gears and overdrive WP pulley, BBK 255lph FP, Kirban AFPR, Kirban Shifter, K&N Cone, 3g Alternator, Energy Suspension Bushings throughout, CHE LCA's, Welded SFC's, and TON's of other parts.
Joe F
Jul 2002
Hawkins, Texas - USA
Just make sure the surface is clean - I use emery (sp?) paper after cleaning up with a scraper.
HTH
