Rod K
Dec 2003
Charlotte, NC, US
Someone told me the Aerostar Aluminum driveshaft would fit a Turbo Coupe. I went to pullapart yesterday and all of the driveshafts were too long. Has anyone else heard they would work?
Rod Kiser, '88TC, 5 speed, 5 lug, Cobra 13" front brakes, Mark VII 11 1/4" rear disc brakes, PiMP'n, Bullit wheels, ATR 3" exhaust, Aluminum driveshaft, EDIS, 60 LB injectors, gutted upper & ported lower. NATO Member
tlswart
Jan 2004
Oklahoma City, OK USA
Long discussion recently.
Searching found this discussion. There are more but this one is the most recent. http://natomessageboard.com/Forum1/HTML/013803.html
Terry: 88TC, 5spd, Gillis valve. NATO Member
Thndrchckn420
Mar 2003
Winchester, VA
A local welder near me said he shortens/balances them for 40 bux. Look for a small welding shop. The bigger the shop the bigger the price. Other shops around here wanted over 100 bux and that didnt include balancing.
88 5-spd. Precision SC-50 ball bearing turbo, gillis, full 3" exhaust w/ 3- 1/2 crome tip, ported E-6, ported big exhaust valve head, ranger roller cam, Essy cam gear, K&N cone in front of the radiator, gutted upper, knife edged lower, Walbro 255HP pump, Kirban AFPR, Forge BPV, PA Performance 130 AMP Alt...
karnage
Mar 2003
Olympia, WA.
If you find the right one, it will fit.I found one at 47 3/8 center to center.Cant remember what aerostar it was.I think its a short van.The extended vans are 55"
