Turbojet
Feb 2002
Connellsville, Pa. USA
Picked up an aluminum driveshaft at JY. My son had one made up for his 86 tc 5-spd.It made a world of difference.A lot smoother and quicker pickup. Don't know if it's because of being alum. or because it is completely balanced, or both. Tried the 180 on driveshaft, didn't notice any shakes or shimmy. Picked up another one for my 88 tc 5-spd. Will be trying it soon!
86-STOCK
87-STOCK
88-STOCK MODIFY SOON
The Family:
86
87
88
zora_d_1991
Aug 2001
milford, ct
how much did the job run you altogether?
"thank you for flying red bird airlines....enjoy the flight."
GaryS#2
May 2001
B.C. Canada
Right on, I'm workin on that too.
Gotta find the Aerostar to steal it from.
Grocery Getter/Rice Cooker.
Turbojet
Feb 2002
It costs me around $160.00 with tax. The alum. driveshaft was 55", the TC driveshaft are 52". They cut the alum. to size, then,they call it high speed balancing.If your universals are good they place them back in or you can choose new ones.
The Family:
86
87
88
Turbojet
Feb 2002
The Aerostar is the one I found.The shop told me it would need universals from a F150 ford truck to fit the TC. The Aerostar driveshaft is a little smaller in diameter then the TC. Nothing to worry about. But if you can find one from a 2WD ext. cab ford ranger, they are the same dia. as the TC. Also they use the same universals.Thats the one that my son found! Hope this helps.
The Family:
86
87
88
Turbojet
Feb 2002
[b]Right on, I'm workin on that too.
[/B]
My mistake, my son corrected me on what ranger. It's a 2WD long bed single cab ford ranger. Sorry for the wrong info, must of been a " blonde moment".
The Family:
86
87
88
Urban Redneck
Feb 2002
St Thomas, Ontario
Will the Ranger one work with no modifications? Or does it still need to be shortened?
Unless you're the lead dog, the view never changes.
Turbojet
Feb 2002
The ranger alum driveshaft is 55" as well as the aerostar. Yes, it will have to be cut. The TC driveshafts are 52", but you can use the TC universals or replace with new ones, your choice!
The Family:
86
87
88
Keith Nubel
Liberty Township, OH
Can you use any year Aerostar? Do they all have aluminum draft shafts? And what year Ranger?
85.5 TC 5 speed, K&N filter charger, Ranger Roller cam, 3" exhaust system, manual boost valve, large VAM, SVO PE computer, front mount intercooler & sport grille, underdrive pulley, ported upper and lower intakes,flow matched injectors, ported E6 manifold, 245/45/17 wheels & Tires,140 mph speedo, under restoration
1985 TC
Turbojet
Feb 2002
The JY we go to are U-PULL-IT type. The vans, trucks, and cars are usally in the early and mid 90's. The Aerostar I found was a 93 or 94. I don't know for sure if all Aerostars have alum. driveshafts. The ranger was a 94 2WD longbed.
The Family:
86
87
88
