alternator pulley
louboy Offline
i have a '85 t/c and am trying to upgrade the alternator.my problem is that i have a 3g-130 amp.which is brand new ,with the serpentine pulley.my stock set-up uses a fan blade cooler followd by a double v-groove pulley.can i get a pulley system for newer style alternator.i haven't seen a 3g for sale for the 85's.i would sure appreciate some help.thanks lou
lou gasson
If I remember correctly,the pulley mounting stud isnt quite long enough when using the double V belt pulley. If that is the case, machine down the inner flat surface of the pulley so you can get the nut on.
louboy Offline
that is exactly the problem.the stud is too short.when i mill the pulley will the belts still line up?.that was part2 of my problem. thanks jeff
lou gasson
I THINK they will line up...... maybe sdomeone else who knows for sure will chime in. If they dont line up, I suppose the alt or back side of the pulley could be shimmed to get everything lined up.
Keith Nubel Offline
I have a brand new 3G that I orderd with the 2 groove pulley and wiring kit for my 85, so yes you can get the correct pulley. I'm just waiting for a warmer day to install it.
1985 TC
louboy Offline
hey keith,where did you get the alt. from.it seems easier to sell this one and get the correct one. thanks LOU
lou gasson
Keith Nubel Offline
Sorry about the delay. I bought from here www.performance.com I bought it with the 2 groove pulley and 3g conversion kit. All I need is time to install it Big Grin
1985 TC
Keith, do you mean www.PAperformance.com?
Keith Nubel Offline
Yes. I guess I got ahead of myself.
1985 TC
