Alternative Mass Air Metering?
Eliminator SS Offline
I have a hard time believing you guys stick with the stock Mass Air Meter after modifying these cars. I can't see it flowing enough air to be much good over about 400hp. What are you guys using for alternative Mass Air Meters, and how are you using them?
1971 Camaro RS/SS, Built 355 Small Block, 426hp. Muncie 4spd. Ford 9" rear.
1979 Camaro Z28, 1974 Corvette LT1, TH350, WS6 TA Rear Axle.
1997 Mitsubishi Eclipse GST, AWD Conversion, Built 6 Bolt 4G63T, Custom FMIC, FP3065 Turbo, 579hp.
84TBirdTurbo42 Offline
thats because there not mass air meters, there Vane Air Flow Meters.
Chris Perry
86XR7auto Offline
Moderator
and the are not accurate over 250ish flywheel hp... hence why everyone cranks the fuel pressure to try to competsate...
I remember reading on TF years ago about the T3 turbo at 19psi on a totally stock 2.3T engine out flowed the ability of the VAM...
That is why modding a 2.3T is cheap to start...but if you want to make bigger power reliably....it starts costing $$.
Travis
Wow so they aren't much good at all. So what's the alternative? Are there ways of putting a mass air meter on these that flow more? If the stock meter only flows 250hp we've already out flowed its capacity. I'll be ordering a megasquirt ecu so I'd assume anything is possible. Are you guys running more HP running speed density or what?
boosted chicken Offline
You can run some type of Quarterhorse or Moates stuff and run a MAF setup but most people (me included) just go to speed density. Much simpler, for me anyway.
RDOG Offline
If you are going to a megasquirt you will be dumping the VAM and wont need a MAS. Many people are running the stinger pimp system.
I'm lazy, so I am having a speed shop install the MAS and he will be tuning with a tweecer. He says my car will run great when he is done, so we will see.
Dan S Offline
The instructions for the PiMP are as follows: :read:
"Remove factory air meter/airbox assembly (VAM) and install a cone filter in its place." :happydance:
Dan S
1972 Ford F-100 SWB Styleside
2015 BMW 435i Hardtop ConvertibleĀ
2022 Escape Titanium Elite
What's the pimp? Is the Pimp what is used with the megasquirt?
Dan S Offline
PiMP is a standalone ECU replacement for the stock ECU.
http://stinger-performance.proboards.com/
Dan S
TurboE Offline
Use a 3 Bar MAP (manifold absolute pressure) sensor with the moates quarterhorse and BE tuning software or pimp
-88 TC Black
-97 Pathfinder
