john shackleford
Nov 2015
northern kentucky usa
88' tc 5spd. Like the title says.. I have no power or vref signal to any sensors under the hood. Also no fuel pump prime. I was driving home one night and it just took a complete dump on me. I've replaced the ircm, eec, eec relay, ignition switch, and bypassed the inertia switch in the trunk.. on my last nerve here.. also I was able to jumper the fuel pump with the diag harness to verify relay operation. The issue is no power from the eec because I have no cel with key on. Please help
Do you have 12 V at all 3 heavy gauge yellow wires going into the IRCM? Check with a test light at the IRCM connector with the connector removed from the IRCM. These 3 yellow wires are protected by fusible links, and all 3 need to be powered up for the car to run. The 3 yellow wires are not all connected in parallel inside the IRCM. Different wires feed power to different circuits in the IRCM. So even if the fuel pump runs vi grounding the EEC TEST connector pin does not mean othercircuits of the IRCM are being powered up.
