turbospoolin23
Jan 2007
Canada,AB
I have been looking for one of those black air valance things that go under the front bumper cover of the car and am having a hard time finding one. I don't see many around are they a dealer option or aftermarket? Well today i was close to pick n pull and had some time to kill so i thought i make my rounds. I spotted a 88 5.0L t-bird that had a valance on it, first one i've seen that is up for grabs. I didn't even have a screw driver to take it off and i'm not sure if i should go back and get it tomorrow because my car is in storage so i can't tell if it will fit my turbo coupe. Someone please tell me it will fit my car without modification.
87 TC 5 spd... 17X9 Cobra R's, .60/.63 SVO T3 Turbo, Large NPR, Manual Boost Controller, AEM Wideband, BPV, K&N Cone, Walbro 255, Kirban AFPR, 3G Alternator Conversion, Short Throw Shifter, Stinger 3" Exhaust, Magnaflow Catalytic Converter & Muffler.
turbospoolin23
Jan 2007
Canada,AB
Here's a picture i took with my phone. http://s271.photobucket.com/albums/jj140...G_0029.jpg Will it fit a turbo coupe?
HCOR
Jul 2009
FOREST HILL MD
I think my 88 T/C has one on there that wrapped around the lower bumper. I'll check tonight and take pics if so.
John
only memories
They are standard equipment on all Tbirds of that era. Without one you run a risk of overheating at highway speeds. The one in the JY should fit your TC.
Here is what a TC valance looks like:
http://natomessageboard.com/uploads/0000...bird11.jpg
turbospoolin23
Jan 2007
Canada,AB
Okay i'm going back to get this thing. I guess i won't know if it fits for sure until spring unless someone else has a definite answer. Thanks guys.
turbot79
Sep 2007
houstonTX
you can also use one from a mach 1 mustang
88 tc, hbc, t3t4, 3"throttle body,3" stinger exhaust, msd, 18psi, Tial 50mm bov, Esslinger adjustable round tooth timing kit, rods header on the way and many more to come
Timmay
Nov 2009
Bolivar, Missouri
Anything will fit anything its just a matter of using some ingenuity and time but as for that should almost be a perfect fit might have to drill a hole and bolt it but all in all should be a simple install and as turbot79 said you can even use the newer mach 1 style valance you have to modify it a lil bit by cutting it down but not a whole lot of work.
1988 Turbocoupe- RIP in a place without rust!
1978 Mercury Bobcat super clean-2.3T, t5 trans, 8.8 rear 3.73 gears 31 spline axles,255 walboro in-line,MBC,3 inch exhaust,4 wheel disc brakes,5 lug
rokatanski
Dec 2009
Charleston IL
The air dam in that pic will fit..
1988 Turbo Coupe (in surgery)
vinnietbird
Jun 2007
Oklahoma
1988 Thunderbird. No details will be given or spoken of.
zbird
Jul 2008
Joshua, Texas
Vinnietbird, that looks great. Did you make it yourself? I would think that would pick up more air and contribute a little to high speed handling.
