Air die grinder lubrication? (Air Tool Newbie!)
vegas_ss Offline
I have an Ingersol Rand 1/4" die grinder, it has a sticker that reads oil daily with an arrow pointing to the air inlet. There is no mention of what type or amount of oil. I searched online and can't find much at all except for the mention of an inline lubricators. The manual is in every language imaginable, with 2 whole pages in english... just shows a diagram of the air line, compressor, grinder etc with a lubricator installed near the compressor.
Do I need to get a lubricator to use this? Do most air tools require lubricators?
As you can tell I'm new to air tools! Just have a small portable craftsman compressor (4 gal) and am planning on grinding the alternator bracket for the 3g install.
1996 Impala SS
daviac5000 Offline
There is a specific oil for these that you should be able to pick up at most auto parts or home improvement stores. I bought some a few months back at Lowes. Just put a couple of drops in the air inlet before each use and you'll be fine.
http://www.lowes.com/lowes/lkn?action=pr...746-403720
'88 TC - Sold
vegas_ss Offline
Thanks!
1996 Impala SS
Joe F Offline
It's called...
wait for it
Air tool oil!
Sorry couldn't resist Big Grin that's really what it's called.
edit: It's just a real fine grade of lightweight oil.
turbo86xrseven Offline
i have used wd 40 on my air tools for years with no problems. It even says on the can it can be used for it
jmthunderbirdturbo Offline
WD40 is good, and i use "zoom spout" oil. google it, its GREAT stuff.
-J0N
Tom Senior Offline
Banned
WE use power stearing fluid or hydrulic oil in the shop. Snap on and napa etc. Sells air tool oil but power stearing fluid works good and its cheap
86 XR7 5spd Offline
so as you can see you can use almost any 'light' lubricant ; jack oil is also light ..
Marvel Mystery oil makes air tool oil too, thats what I use
its cheap and you only use a little so it 'last long time' ; splurge on a little container of good stuff Smile
I am really getting tired of oiling my air tools daily ... I have about 11-12 different .. takes a lot of time...
David T
2.5" exhaust w/ cherry bomb
Martin Offline
THe cheapest ATF you can find. All that we have used in our shop for years. Needs to lube but also seal and some smaller slower moving tools plain light oil allows blow by and reduces the tools' effectivness.
MArtin
Boost High, Fly Low
OU812MACH1 Offline
all those above will work ..i have 3 or 4 different shops i sell to that swear by air tool oil by BLASTER..it has conditioners for the seals and the small fins in side the tool..
o4 mach-1,white,4at 1 of 169 ,MAC air filter and x-pipe, SCT tune / o9 BMW 328 M-SPORT, white, 6at/ 87 Turbocoupe ,white,4at,KIRBAN afr,GILLIS boost valve,Garrett/SVO T3,cold air,3" STINGER down pipe and tail pipe, DYNOMAX ultra flow stainless muffler, Walbro 255L fuel pump,cleaned and flowed injectors,STINGER BOV, built A4LD trans w/all
4x4 Explorer guts, K245/F57FA torque converter.
