Ross
Nov 2009
Brighton, Michigan
I was just wondering how much freon the 1988 TC take and what type of AC oil they use. Thank you
RossTheBoss
1988 TC, White, 5 spd, K&N, and Manual Boost Controller
Not B Anymore
Nokesville, VA, USA
R12 Capacity is 40 Ounces +-2oz.
Oil type is ESA-M2C31-A - 500 Viscosity
Oil Capacity is 8 Fl. Ounces
This is assuming it is the same system as the '86 as that is the book that the info is coming from.
Hope this helps...
lonstar7
Jun 2009
Round Rock, TX
Mine took a little over 3 cans (12oz) when I changed it over to R134a.
Lonestar7
