What kind of coolant does an 88 TC use?
R-12
and jack rails.
I mean refrigerant... sorry bout that
turbocoupeterry
May 2001
lima,ohio united states of america
has ne1 tried to retro-fit their bird with a r-134a if so i wouild like to kow the procediure and if its worth it
88 tc, new tires and a k&n filter fender mounted
TCx2
Sierra Vista, Arizona
I've had two birds converted to R134. Completely drain the system. Get a new dryer. Replace all the seals. Replace the fittings and you are off and running.
R134 doesn't get as cold R12, but it is doable. Difference is in my whitebird with R134 I am rarely tempted to turn the A/C down. My blackbird with R-12 I will sometimes turn down the cool.
Last bird I had converted cost (with labor)
about $275.
Kevin
TCx2
88 White TC, 5spd, Loaded
88 Black TC, 5spd, Base
87 LtBlue TC, 5spd,Loaded
Kevin
TCx2
Walsted
Fort Worth, TX
I'm running R-134a from the Interdyne kit. A local shop evacuated the R-12 for free provided I let them keep it, and I did the conversion as specified on the box. The A/C works, although it is noticeably weak. I asked a friend who is an A/C mechanic about replacing the dryer and o-rings, and he said that it was a good idea, but not necessary.
Mike Walsted
1986 5-speed TurboCoupe .
TCx2
As far as dryer, I was told the same thing. I didn't HAVE to replace it. However, any car that I've converted I've had leakage problems that caused me to have to do A/C work. Thus I changed all the o rings. I have one bird that is still on R-12. Pretty sure the compressor is going to die as it is noisey but until it does, I'm leaving the R-12 alone.
As far as dryer, again was told it didn't have to be done, but a 13 year old dryer...
decided that I wanted the best I could have since I knew R-134 was inferior in cooling properties to start with.
Kevin
TCx2
Kevin
TCx2
I've converted all 3 of my TC's.The '83 was the first & I didn't install a new drier & it's still fine after years of use. Time after time I see posts saying R-134 isn't as cold. How is 38 degrees w/ r-12 colder than 38 degrees w/ r-134?? When converting, you only charge 85% of what the system originally used or you'll get higher pressures and it won't be as efficient.
Dave
'83TC
'85TC
'87TC
'90SC
