oldone
Aug 2001
Panama City, FL
Just the other day my AC system started acting up, the problem comes into play when i start to accelerate. During acceleration the AC will quit blowing out of the dash vents(still blowing out the lower vents) and will not return to the dash vents until i have leveled out at speed. While cruising steady state it seems to be ok but as soon as I depress the accelerator it seems as if the vent close off. Its not an electrical issue since the blower motor never changes tone, and there is no flux in the lights or the amp guage. Also sometimes when im cruising at around 45 and go to use the cruise control to accelerate, you can feel the gas pedal go down and then all of a sudden it will just come back to normal while im stil depressing the button. Its possible the 2 issues are interelated. Im thinking it's a vacumn issue but im not sure where to start. Any help is appreciatted.
Thanks
oldone
88 Maroon TC 5 speed
K&N Filter
Gillis boost valve
220,000 Miles
Manual system I assume, not the EATC?
Sounds like you have a problem with the vacuum coming to the heater controls..When you open the throttle you lose your engine vacuum and apparently the canister is not holding enough to keep it working.. Check your vacuum lines to the vac cannister and to your heater controls.
4cammer72
Jul 2005
swansea, sc ,usa
mine does the same thing. when i give it gas it changes from the vents to the defroster on top of the dash. i can hear the door opening and closing in the ductwork. wheres this canister you are refering to?
oldone
Aug 2001
Panama City, FL
Yes, it is the manual system. 40Bob, where is this cannister that your referring to?
Thanks
oldone
K&N Filter
Gillis boost valve
220,000 Miles
The canister is in the passenger fender, I believe
Defrost is the default position when there is a fault with the control system (vacuum)
There is also a one way check valve in the line to the vac canister in the fender. Be sure the valve is working correctly.
oldone
Aug 2001
Panama City, FL
So i guess im looking for a split or loose vacumn line, and also to verify that the check valve is functional. Do you get to this cannister by removing the inner fender well?
Thanks
oldone
K&N Filter
Gillis boost valve
220,000 Miles
oldone
Aug 2001
Panama City, FL
The problem is solved. I removed the inner fender liner and found the vacumn line broke. After a quick repair it's back to business as usual. Thanks to everyone that offered help, would have take much longer to locate on my own.
Thanks again.
oldone
K&N Filter
Gillis boost valve
220,000 Miles
