Aftermarket struts, for an 85,,,
Riverratt Offline
All I am finding for the front struts is Monroe Sensatracks...
This is not acceptable (unless it is all I can get).
I have read that period Mustang struts, are shorter, but will they WORK?
With the later SN94 front struts work ON THE OLDER (1985)Turbo Coupes?? My suspension is in stock configuration with the exception of polyurethane bushings and such.
If not what will?? and what would you suggest..
Current Turbo Car, 1985 5 speed TC. TC intercooler,87 TC hood, 3 inch down pipe, cat delete with 3 inch tailpipe, K&N cone, T3, Gillis, Dual piston BOV.
Past Turbo Cars
1-1987 Dodge Shelby Z Daytona
1-1986 Dodge Shelby Charger
1-1985 Dodge Shelby Charger/ Intercooled
1-1985 GLH-T Dodge Omni
CB900Fer Offline
I've heard that KYB AGX shocks from a 94 Mustang work (but they are shorter, like you said. So you will lose some suspension travel).
But I went with KYB GR-2 up front, and KYB Gas-a-just in the back. I ordered them from Summit. They seem to work fine.
My 88 had PRCs on the front that I thought were bad, but when I went to the GR2 they were actually a little softer...not bouncy, just softer. I'm looking into getting new coil springs that should help that out a bit though...
1979 Honda XR250
1980 Honda CR80 Elsinore - sold
1981 Honda CB900F Super Sport
1988 Ford Thunderbird TC - 2.3T, 5 speed, K&N, Gillis, dynomax dual exhaust.
Ballman Offline
If your still looking , I got a pair of new take offs, were on a car then right back off. they are the KYB - GR-2 front struts, I bought a whole kit springs and all, but i can split them up. let me know if your still looking for struts. Think have have the new strut bushing to, just pends an what you want . Im in Indiana . [email protected]
DW
Riverratt Offline
Hmmmm, thanks for the info, Ballman, you will be getting an email from me in a day or two. I am working alot, and I am half way out the door right now!
I would like to talk to you about the KYB's.
Past Turbo Cars
Ryan50 Offline
So the GR2 will work on the *non-programmed ride control cars cause i dont have the turbocoupe package?
turbobird63 Offline
Actually I have the Sensa-Tracs and all energy suspension parts up front and its Perfect!
Christopher Taylor
85 TC, 2.3l, LA3, T3/T4 Turbo 25psi, Stinger FMIC, Forge BOV, Full 3" Exhaust, Esslinger crank pulley- Timing Gears and overdrive WP pulley, BBK 255lph FP, Kirban AFPR, Kirban Shifter, K&N Cone, 3g Alternator, Energy Suspension Bushings throughout, CHE LCA's, Welded SFC's, and TON's of other parts.
