gmaibach
Sep 2008
Sterling, Ohio
are the ebay stainless steel headers any good... theyre only 200 bucks and i can reinforce the welds.
1988 Turbo Coupe 5 speed Red with Red cloth interior, K&N cone filter, Ported IHI turbo, ATR Header ported, Manual Boost Controller at 18 psi.
2013 Focus ST 2.0 Turbo, Buschur green filter, OCD Speed axle back exhaust.
SHOcoupe
Aug 2009
New Jersey
No, they are garbage. They don't use the proper filler wire for the welds, which causes them to crack after a few heat cycles and some spirited driving. The piping is a thinner gauge as well.
Get a stinger header instead and save yourself the trouble.
88 TC, FMIC, GT35-1 .70 A/R, 42lb Injectors, MS2 p&p, Custom upper manifold, junk heap Stinger header, 3 inch exhaust, Accufab FPR, Bo-Port 1.9 cam, Oversized valves, ported head, Stage 3 clutch, 22psi.
gmaibach
Sep 2008
Sterling, Ohio
i was wondering... i read the feed back and he only has a few negative and that was because of wrong parts... and they say its guaranteed.
bang4thebuck
Jul 2004
pennsville NJ
Save a tad more and get a bob's log. Itll never crack and performs awesome!
gmaibach
Sep 2008
Sterling, Ohio
well it aint exactly a want its a need... my stock e6 has a hole in it and my neighbor has been takin me to work the last few days and im completely broke
86XR7auto
Mar 2003
Mt. Pleasant, MI. USA
I would post in the wanted section for a E6 manifold. That is the stock manifold/header used from 1985.5 to 1988 should be able to find one cheap.
Travis
Sir THEY CRACK i have a couple that did. But overall its a very good manifold. Have a great day Sir
jangus
May 2008
Nebraska
Any pictures to back that claim up? What year did you buy them? I know Bob's redesigned them at least once.
88TC 5speed, 160,000+, ranger roller, Evergreen T3, cone filter, manual boost controller.
One parts car still waiting to be taken apart.
Waiting in the garage: SC throttle body, SC intercooler, graphic equalizer, among other things.
The original Bobs "small log" had a few problems with cracking, but AFAIK, the third generation "big log" doesnt crack.
bang4thebuck
Jul 2004
pennsville NJ
Let me re-phrase that. A bob's log will not crack as fast as anything else tubular by far. I run mine without the brace and no cracks! From what I read everywhere I see people complaining about how their tubular header cracks all the time and needs to be re-welded ALL THE TIME! If it were me, I'd get a little spot weld on your e6 to hold you over so you can save up for a Bob's log.
