So I just did a T3/T4 swap on the 88TC, also put my ported E6 on it while apart. Initially when the IHI was on it, I turned up base fuel pressure to 40psi, now with the T3/T4 at boost, 20psi, my AFR goes rich at like 10:1 even. I know more boost, needs more fuel, but does this seem overly rich? the IHI would run mid 10 AFR on the Autometer wideband, so what's the best way to adjust the AFR? Fuel pressure, or VAM? Thanks
