SHorten the rod for the WG to open at higher boost.
It still wont work as well as a GIllis, though, and be a much bigger PITA to adjust. Even if you shorten the rod, the WG will still open slowly as the set pressure is reached causing slightly longer spool up to max boost. The Gillis doesnt let any boost press get to the WGA (keeping the WG fully closed) until the set press is reached.
