I want to add illuminated entry to my 88 TC. I found the module, but I didn't have time to get the wiring and everything.
What I did find out is that the wiring goes from the module (on the driver-side electronics tray behind the back seat), then goes under the passenger-side door sill. When it gets to the area in front of the passenger seat, it goes toward the center tunnel. I lost it at that point because I didn't have the time to remove the seat.
Also, I took the light-up lock cylinder out of the door, and it appears that the light ring is pressed on to the cylinder. Is there an easy way to get that off, or will I have to find a TC with an ignition key and get the door/ignition lock cylinders too?
88 TC 5-speed
