Is there a way to get the actual color code for the interior? I'm going to be installing a dash cap and want to get the proper matching paint etc.
The car was painted with code 7F. It can only be either gray or blue, just want to verify since age can fade it etc. Thanks in advance.
Ok, by doing a little research I found it. But if you have any useful information on the dash cap please feel free to post it.
andrewjs18
Aug 2012
Philadelphia, PA
(07-06-2019, 03:53 AM)Entropy1988 Wrote: Ok, by doing a little research I found it. But if you have any useful information on the dash cap please feel free to post it.
would you mind sharing said information you found? I'm in the process of having some interior plastic trim pieces developed and would like to see if there's any available paint/dye that's close to the factory interior colors.
I will scan in the page from the manual when i get a chance. The ID codes are on the door pillar ID tag.
firebirdparts
Dec 2017
Kingsport, TN
(07-06-2019, 05:18 PM)Entropy1988 Wrote: I will scan in the page from the manual when i get a chance. The ID codes are on the door pillar ID tag.
Autocolorlibrary.com has old ppg paint chips and some (most) of them will have interior formula numbers. Like for instance this:
http://images.tcpglobal.com/chips/1988-Ford-pg04.jpg
You may be able to buy these colors and you may not. It just depends on whether the people currently in the game bothered to keep up the formulations.
