Accurate Gauges
Birdman78758 Offline
If we've got any EE people, do you think it's possible to take a standard instrument cluster and upgrade some of the components (resistors, capacitors, etc.) to better specs (milspecs) so that it would be accurate?
Just a thought...
Not really many resistors, caps, etc. in the cluster you can get to. the oil, temp, fuel gauges are just bimetallic strip gauges, and you cant do much about those. The senders are crappy too, not to mention the 50s tech mechanical IVR. The IVR can be upgraded to solid state pretty easy. Tach and speedo accuracy is more a function of the return spring on the needles than anything electronic.
Thanks, Jeff. Sounds like you took a close look at some point. I guess that with factory-specs and "50's" technology it's not really worth it. No wonder they're considered a POS.
