AC Question
Pony Boy Offline
Why does my Blower door open when I turn my a/c on to panel?The door closes when I put it on defrost or floor,but it opens up aagin when I put the control back to panel.I also have the electronic climate control.Thanks for any help!
1986 Turbo Coupe,K&N Cone Filter,Gillis Boost Valve,3-Speed Automatic,1987 Turbo Coupe Hood,Stock 1987 Intercooler,LA2, Big VAM.
Blower door? Do you mean the blend door? Do you mean the fresh / recerc door?
Pony Boy Offline
It's the blower motor.It's located under the glovebox on the passenger side interior.There's a "foamish" door that will come down when you turn the heat on.
trashline Offline
Jeff isnt that the door that allows the system to pull the air from inside the car? like the return for a central A/C system? this way the car doesnt have to work so hard to cool the air again if it can pull it from the already colder air then the outside?
Brian
www.BCPCustom.com
06 Cobalt SS
Brian is right, that is the recycle door for the "Max" AC position
I am not real familiar with the EATC system, but it is likely it is working correctly if the fresh/recerc door opens in A/C, which will cool the car more quickly as Brian pointed out.
Pony Boy Offline
Alright,thanks for the answers.I just wasn't sure about that door being open.Thank You!
