(This post was last modified: 03-16-2019, 08:51 PM by andrewjs18.)
AC Compressor Clutch Disassembly
by Steve Beem
by Steve Beem
Step 1: Remove the nut in the center of the pulley.
Step 2: Remove the cover plate. While it does appear to have internal threads in the center both that I worked on just fell off.
Step 3: Remove the large nut that retains the pulley. I used a hammer and a punch alternating hitting the two sides.
Step 4: Now the pulley is loose and can be removed. The bearing is in the center of the pulley.
Step 5: The clutch can now be removed. Notice the tabs on the compressor and matching holes in the clutch. Since there are only 4 of them it is fairly simple to get the clutch (and plug) clocked correctly.
https://tbirdcougarparts.com
-Andrew
-Andrew
