ABS Troubles
Chris R. Offline
I have the ABS light on so I searched on how to pull the codes and came up with code 22. Here's what the chart says about it --> http://www.tbirdheritage.com/articles/ab...stepid=CC1
Well what exactly do I need to do here with the valve block? It measures 9.5 ohms between pin 6 and 7 therefor its throwing the code. I've never messed with the Teves system so I have no idea what needs to be replaced. Sad
Gary F Offline
Never Mind.
Gary Fraser
'88 T5 Bone Stock w/3G Alt.
The official line from Ford is to replace the entire MC assembly if a valve is found to be bad.
Chris R. Offline
Time to switch over to vacuum assist I suppose.
