ABS and Ride Control Wiring removal
Jeffmerkur Offline
Hi Everyone,
I was wondering if it was possible to remove the ABS and ride control parts of the wiring harness with out cutting up the harness in my 88.
I am no longer using either of these systems on my track car.
Thanks,
Jeff
Jeffmerkur
They all run together in places. It's been done but not an easy task
HCOR Offline
Jeff I would pull it all and run an 85-86 engine harness. From what we talked about it should work out for your track car. you can then wire you battery feed and accesories new.
only memories
Jeffmerkur Offline
Right now it would be easy to switch everything.
The car is completly gutted. My only problem is time. Car is signed up for Hyperfest at Summit Point in 2 weeks. There is a whole pile of wires and plugs that I'm not using in the current harness. Do you have everthing I would need? I was thinking I would replace the harness with a painless harness and then use an XR4Ti engine harness that I have here. I already have an LA3 thats been repinned to work with the XR harness.
Jeffmerkur
HCOR Offline
that sounds like the way to go, probably pretty much same harness as gthe older tc.
only memories
Notch Offline
Get a good wiring diagram and backtrace everything and get rid of it and clean it up. It sounds a lot easier than it is, but I would consider it the "right" way to do it.
TurboCoupe50 Offline
Agreed, unfortunately the EEC test connector is in the ABS/ride harness... It connects to the engine harness via a connector near the 'puter... After I did my 5.0 swap, I had two EEC test connectors with the original being inactive... I used the wires in it's plug to connect gauges, sure beat running additional wires through the firewall...
1988 Turbo Coupe331 AOD
1972 Comet GT
1969 Fairlane Cobra 428CJ 4-Speed
