ABS
stitchrr Offline
Is there any info on diognosing problem when the abs light is on? i didn't see anything in the tech topic for just the abs.
RJR
goldwing Offline
Mine came on when the little brake pressure switch sensor went bad.
The sensor I'm refering to is located on the distribution block/all the metal lines into one block,... its on the fire wall, just under the end of the big metal block at the end of the fill bottle.
I suppose it could be a number of things though.
Of course the first thing to do would be look for any obvious leaks and low fluid level.
T.C:87 5 speed
stitchrr Offline
no leaks. will check the sensor. are these available new?
RJR
^^^^ the brake pressure switch has zero connection with the ABS system. The switch is only connected to the PRC system, which, in turn, isnt connected to the ABS system in any way. Only way the leaking switch could set off the ABS light is if the fluid level dropped due to the leak.
To the OP..... you can run the ABS codes using the ABS test connector in the trunk and watching the ABS light flash out codes. The most common problem is the cables to the wheel sensors breaking internally due to 25 years and hundreds of thousands of miles for flexing. Wheel sensor output and cable integrety can be easily tested using a DMM. I think there are instructions somewhere here or on JTs site (tbirdheratage or something like that). Another common problem is rust on the tone rings or sensors themselves interfering with the magnetic field between the sensors and tone rings. Even loose wheel bearings can set an ABS code as the gap between sensor and tone ring is upset.
See this about pulling the ABS codes, a good place to start.
http://natomessageboard.com/cgi-bin/ulti...114#000000
goldwing Offline
Well, that means I have a problem too.
I thought my pressure sensor was the issue.
I never found a new switch by the way. I just plugged it/welded it shut.
T.C:87 5 speed
stitchrr Offline
thank for all the input so far.working on it
RJR
