I'm trying to adjust my TPS for the first time and I can't get past step 2 - unplugging the Idle Air Control. Is the IAC described in the instructions:
"This device is a round cylinder approximately 5 inches long with a (2) bolt flange and 3 wire male / female plug connector" just above the TPS?
Because my Ford shop manual describes this as the Air Bypass Valve and it only has 2 wires. There is mention of an Inlet Air Solenoid in the manual but I don't find a picture/location for it.
fun, fun, fun - Justin
3" DP & Cat, Magnaflos, K&N, Magnecor Race wires, Steeda Tri-Ax, 3-core radiator.
3" DP & Cat, Magnaflos, K&N, Magnecor Race wires, Steeda Tri-Ax, SPEC Stage 2 clutch, 3-core radiator.
