Has anyone mounted gauges on the A pillar? Which pillar pod did you use?
Thank you
Dale
I have a vacuum / boost gauge and fuel pressure gauge on the A pillar. Did it years ago. I think I got the 2 gauge generic gauge pod from either Summit or Jegs and painted it to match my interior. FYI, if you are thinking about trying to use a FOX Mustang A pillar gauge mount (i.e., the entire Mustang A pillar) it will not fit the TC.
BradM
Dec 2020
Barrington, Illinois
I used the Auto Meter 10101 pod and the Perfect Tuning gauge. I'm happy with the fit.
1965 Mercury Comet Caliente; 1968 Mercury Monterey; 1969 F100 Ranger; 1987 Thunderbird Turbo Coupe; 2017 Police Interceptor
88Slowbird
May 2019
Tampa, FL
I used Autometer #10120 its an SN95 pillar pod it fit great
Black 1988 TC: RR Cam (with Esslinger cam gear), Stinger FMIC, Stinger 3" Exhaust, .60/.63 SVO Turbo, Pimp V1.4, Spartan2 Wideband, Bypass Valve, Hurst Short Throw
Mach 1 Red 1988 TC: Steeda Tri-Ax shifter, manual boost controller
